On my B-body I've got some pulley changes in the works due to working on an aftermarket A/C installation, but this weekend I'm also trying a new higher flowing Flowkooler water pump.
I've noticed that stock replacement water pump pulleys for cars with A/C are smaller than the crank pulley and stock replacement water pump pulleys for cars without A/C are usually a 1:1 diameter between the water pump pulley and crank pulley diameters (and some are even a little bigger diameter).
At the same time, OEM water pump impeller design seemed to target slower moving coolant (less vanes) for A/C cars. I didn't realize until just now that it may be due to countering some of the opposite effect from the smaller water pump used on A/C cars.
So for a stock configuration we're seeing 2 things:
Non-A/C car: larger water pump pulley (not overdriven compared to crank pulley diameter) + faster moving coolant (higher pump fin count)
A/C car: smaller water pump pulley (overdriven, faster moving pulley) + slower moving coolant (lower pump fin count)
On my originally non-A/C car I currently run a stock 1:1 pulley ratio (larger water pump pulley) + lower fin count water pump. This does not match either of the above stock configurations. Right now the car runs between 185-195F in normal stop and go traffic or speed (Excellent), but has occasionally crept up to 215-230F after extended idling (20 min) and immediately cools back down after 30 sec of 20mph or more. This weekend Since I'm not able to find any smaller single groove water pump pulleys of the correct depth (unless I buy this one and shim it from the back - not sure if that's ok to do....)
I'm installing a high flow high fin count Flowkooler water pump to get more coolant moving at idle.
Anyone using this smaller single groove pulley? Can I adapt it to my non-A/C setup for the time being with shims to align with the crank and alternator?
Mopar Plymouth Dodge Fan pulley 340 383 440 1 1/4 X 5 7/8 Cuda Challenger OEM E | eBay
So for my future A/C plans that I've started -
I've got an overdriven water pump pulley (smaller water pump pulley, larger crank pulley), so that's good. Would it be ok to leave the new faster flowing Flow Kooler water pump installed with the smaller diameter water pump? Or when I swap the pulleys during the A/C install (still a few months out), should I re-install the lower fin count lower volume water pump? I've read some have cured idle heat issues, only to create a new issue where the higher pressure from the higher flow pump creates an overheating issue at faster engine speeds (3000 RPM highway).
Has anyone run a smaller water pump pulley along with a high flow water pump like Flowkooler and not had any overheating issues at idle or any speed?
