SOLD 1966 Charger part out
droptop2bottom
3:06 AM
great white north
Feedback: 8 / 0 / 0
Lots of parts for 66-67 Chargers. Much more than
pictures. $20 and up.
Would you have any very good used 66 Charger trunklids? Looking for a friend. Thank you for your time!
I need the two rectangle emblems.
Do you have the two 383 four barrel emblems? I need a decent front hub (10in).
Emblems inv the picture sold. I may have another set. No 383 emblems. I should have a hub.
Hello
I am interested I the rear interior sail panels . How much are you asking for those . Thanks
Do you have any parts left?
looking for the trunk plastic thst covers the tail lights you still have it if so how much need one
Do you have the quarter window rollers, limit switches, power pack, bulk head connectors both sides, hold open switch, ac vacuum switch, heater control valve, instrument cluster to dash frame mounting screws, sill plates, here's the tricky one the Dr door handle got pushed down and damaged the door, I need a piece of the door where the handle mounts into, maybe 3 inches larger than the door handle mounting spot. I have to cut it out and weld in the new metal.
