Strykr73
I was at the Mopar Nationals in Carlisle recently and had some opportunities to talk to other Charger owners, particularly some mid 70's owners with 318's like mine. One interesting and disturbing revelation is that somehow, throughout its life, my car seems to have had its distributor swapped out. Normally that wouldn't be a big deal, but the distributor that was swapped in does not have vacuum advance. All model cars at this point in time would have had a vacuum advance distributor installed from the factory. I confirmed this with one of the other '73 318 owners who was there at the nationals, albeit their car had the 4-barrel 318.
So my question is...
Which distributor can I swap into place of the existing one without having to modify anything else in the system? The car has "electronic ignition" from the factory with the firewall-mounted voltage regulator and ballast resistor. It also has a separate ignition coil mounted at the rear of the engine next to the distributor. I've taken some pictures.
What I'm looking for is just a distributor to drop in place which has the vacuum advance on it. I am open to replacing the coil if needed, but not removing it.
Do I even need to worry about this? She runs fine as she is now, just without any top-end power. Suggestions, recommendations, and questions welcome!
P.S. At the same time, I'd like to add a tachometer to the car, so making sure the distributor and coil are compatible with a tach is a must. I picked out This One as at least a temporary solution. I find that having a tach is incredibly helpful in doing diagnostics. It's bizarre how all modern cars have them, but rarely need them, and antiques rarely had them and definitely need them!
