1966 versus 67 Plymouth glovebox door ??
gtx6970
Tucson AZ
Whats the difference ? or is there one ?
I see them listed for 67 GTX.
But not for 66 Satellite
Cluster bezel appears to be the same ?
I thought they were identical for Belvedere II, not sure about the others.
The cluster bezel is the same but a 66 has the Plymouth emblem in the center.
66-67 Belvedere/gtx/Satellite gloveboxes are the same I think. The difference would be in the emblems for the different models.
The cluster bezel is different between 66 and 67.
Ok.
Ive found glovebox doors for 67 gtx.
But not for 1966 Satellite.
PG advertises the cluster bezel as the same between the 2
Correct about emblem.
I believe the glove box door is the same.
Coronet is.
The glove box doors are the same. I had one of both - no difference.
If you disregard the emblem holes as the R/T and 500, has no holes for an emblem.
I think the OP is concerned about year to year, but model to model and emblem holes is a valid point.
