driveshafts between 66 Plymouth and 67 Dodge
gtx6970
6:09 AM
Tucson AZ
Can anyone tell me how much a difference is the driveshaft between the 2 cars
I have a vibration in the Plymouth.
And can try / test drive with the shaft from the dodge to insure its my problem before I go have a shaft made for the Plymouth
Both cars have 8.3/4
I can also swap shaft with my 66 hemi Satellite.
But it has a dana in it which i know requres shorter shaft.
Havent ckd U joint sizes yet. So i might be barking up a tree .
Im just trying to do a test swap to make sure my problem is in fact the shaft before i take it and have ckd for straightness and balance
If you run the Dodge shaft 52" I believe it won't be a problem. Just check that you have some space for in and out movement. I put a 52" in my Satellite seemed OK but wouldn't run it for long. I had 2 66 d shafts and didn't know which one belonged to my Satellite.
Stupid question. Are your tires recently balanced?
Tires are balanced.
But Im 99.9 percent sure this is NOT a tire vibration.
Im switching from chrome magnums to Torque Thrusts to see how well I like the look in person.
And the TQ were on my Coronet with no vibration what so ever
That’s a pretty car. :thumbsup:
switched drivesahft between the 67 coronet and 66 Satellite.
vibration gone .
So now to have the correct one for the satellite ckd for balance and I'll put it back in
Thanks all
also, swapped wheels
just for grins to see how I like the look . Jury is still out . I cant make up my mind if I like it ,,,or not
