Breaking the spot welds would point to inadequate welding technique's and quality. Don't think I'm going to have that issue.
Burn it in Baby. Hell Yeah.Breaking the spot welds would point to inadequate welding technique's and quality. Don't think I'm going to have that issue.
The awb cars had the same b pillars as the sedan, they were severely weakened by the acid dipping and only a few teams knew to tie the frame from the start, ultimately all were reinforced in some way, the launch is what was bending the bodies, front end damage was the result of the “wheelies”Yes, look back at the 65 altered wheelbase factory cars, all hard tops and the were bending like crazy. Chrysler tried to get the racers NOT to do wheelstands. Eventually they became bent beyond repair
All altered wheelbase cars from the factory where hardtops, races took the normal 65 sedans and made them altered wheelbase cars.The awb cars had the same b pillars as the sedan, they were severely weakened by the acid dipping and only a few teams knew to tie the frame from the start, ultimately all were reinforced in some way, the launch is what was bending the bodies, front end damage was the result of the “wheelies”
Yes, the factory cars were hardtops, but had the B pillar added, just like a sedan as the above photo shows.All altered wheelbase cars from the factory where hardtops, races took the normal 65 sedans and made them altered wheelbase cars.
THANK YOU! You jock my memory I remember my friend telling me about repairing big truck semi frames sometimes he would see failed repairs for people use square edge steel not rounded edge cuz the frame rails were designed to flex. That also echoes a sentiment of improperly installed repairs or stiffeners.You got to remember if it don’t flex it breaks. Great for a car that goes over 100,000 miles. Truck frames have a definite cycle time like 200,000 cycles, weld on it and that time goes way down and will crack. Ships, planes and any other big vessel are DESIGNED to flex, think of the 1000 + foot oil tankers. Ever seen the railroad tracks welded? They bend up on a flatbed trailer, welded, Then the trailer is moved to the next section as the welded section lays back on the rail bed like a noodle. A cage IS the chassis, the body just hangs on it like a painting.
