bolts bolts and more bolts
cinciaz
1:08 AM
Arizona
Hopefully this is in the right place for this thread. 1971 charger 383 mag. Sooooooo I have looked and looked for a manual that will give all the bolt sizes and where they go. Can anybody tell me what size are the 4 water pump bolts. I have a service manual (CD) but that was no help.
I know there is an expensive book out there that gives every detail about every bolt used on these cars but I do not know the title. My car would never get done if I bought it!!!
In the torque specs in the factory service manual (paper edition) they call for 3/8 -16 for water pump to the housing. They don't give length so you can figure that out. Also housing to block is a 3/8-16 bolt although longer.
i think that the w/p bolts are a specialty bolt. the reason i say that is, if i remember correctly, they have a drill hole that has nylon in it. they don't use a lock washer as they would rub the pulley.
Found a cool thread , no pun - Someone did some hard work on A Bodies forum
Says bolt head not included in length
Oh my gosh you guys are great my first ever post on here and I got an answer within an hour I’ll check out that book but it only goes up to 1970 does that really make a difference. Again thanks for everybody chiming in if this always happens when you post a question I’ll be done with the car in two years instead of six lol
The E body book might be closer to 71-74 B body. Engine hardware should be mostly the same though. Here's a link to all their books.
Products | MMC Detroit
Thanks for the link... Man those books are expensive.
