1970 roadrunner firewall
tracy
indiana
Should a 4 spd car have similar plugs like these ? I see alot of 4spd cars don't have
1970 B-body reverse lamp wires come through in the wiper motor plug.
Probably wouldn't sho
W
Seems like thers alot of charger wiring in harness that I don't use for roadrunner
I take it you haven't looked at one then, because you wouldn't be guessing all over the place.
Don't guess....know.
Yes, the factory wiring diagram not only shows what's hooked up and where - but it tells you
the colors the factory wiring was for each wire.
The problem is the harness is not model specific. But thank you for your input
