Which gear ratio
440gtx1967
11:44 AM
canada
Which gear ratios do you have on your stock 440 with stock heads, cam, carb and auto transmission...
I am confused as why Plymouth only had the 323 as optional gears on the 440 in 67..
I thought a 3.55 was available as an option but maybe it came later.
I think the choices were 3.23, 4.10 with 3.23 being standard on the GTX. I also think you could order higher gears in the high 2's. In the Dana 3.54 was the highest gear. I to am unsure about 3.55's.
Interesting as the rear axle in the back of my Bee came out of what I remember was a '66 Charger... but it could have been anything 1966 in the junk yard at the time. 2.94 Suregrip 741 case.
Interesting as the rear axle in the back of my Bee came out of what I remember was a '67 Charger... but it could have been anything 1967 in the junk yard at the time. 2.94 Suregrip 741 case.
All GTX'S with 8 3/4's were 742 housings. The 741 housings were for the small blocks.
I have a 742 case, 3.55 sure grip with factory gears, but don't know the date code.
A 3.23 is a really nice, all around, driveable gear set to run with a big block. The key word is driveable. After that it's a choice on a gear set for more performance or a taller (lower numerical number) for more highway speed at a lower rpm. I think Mopar had it right to start with a 3.23 back in that time period.
Tom
1967 GTX with automatic was 2.94 and 3.23 only
1967 GTX with 4speed was 3.54 only.
Does that mean if you ordered 4.10 gears in 67 that you got a Dana? I remember that when I ordered my 67 Satellite 383 4-speed car, I was asked what gear ratio, but no longer remember the choices.
Here is the deal, You couldn't order 4:10 gears from the factory in 1967 Chrysler Corp Passenger cars.
you could get dealer installed gears in whatever ratio they had, and trucks had many ratios.
Has anyone ever seen a 1967 GTX coded for 4:10 gears on the fender tag or broadcast sheet? I never have.
I will be the first to mention the 1967 RO and WO super stock cars had all sorts of racing gear ratios available, but those don’t count here.
I remember when we ordered one new and there were only 3.23 or 2.94 on auto.
Suregrip was optional = I think only about $50.
I "think" 3:23 was standard and 2:94 was a no cost option.
My 67 Hemi 4 Speed had a 3:54 and there were no other options.
Suregrip was standard on all Dana 60 Cars as well as Dual Point Dist. even
on 440 cars equipped with 4 speeds. .
I like 3.55s, but you have to run an overdrive. I ran 3.23s on my stock 440 with a 4 speed, it didn’t feel like it had the torque a 440 is known for. I put 3.55s in it, and I’m a lot happier with it. Of course you have to take in consideration of your driving, if you are still a child 3.55s are great, if you act like an adult and only go out for Sunday drives, 3.23 is fine :lol:
With a 0.72 4th gear, 27” tire, and 3.55s, I can run 80mph at 2500 rpm:thumbsup:
80 mph in my car was a taste over 4000 rpm.
When I daily drove these cars I found a 3.23 440 setup was awesome for burning up the highway going 250 miles to work or ratting around town. I could run it up to 140MPH when I felt like it and they still ran good in the city. 3.55 is too low for the type of highway driving I do.
A buddy bought a new 1968 Road Runner with optional 3.55 Suregrip in 8 3/4" , so I think this is first year for them. 1969 saw more ratios become available. My new 383 Super Bee came with factory 3.91 Suregrip 8 3/4" . You could now get 4.10's in a Dana 60 (standard on A12 cars). I read of people having 3.73's in their 8 3/4's, but this was never a factory gear. Either aftermarket, or just a mistake. I think this was a GM ratio.
We swapped a A12 Dana for a 8 3/4 when the A12 owner was trading it in back in 1970.Put the Dana in my brothers 68 R/T.
My 66 Charger had a 2.94 Sure Grip in it when I got it.Stock poly 318 car.
Gear ratio (for me) depends on the area you live.Flat,straight,mountains,hills and the type of driving you do.
