FOR SALE 1970 383 engine/heads
NTOLERANCE
11:06 AM
Madison, WI
Feedback: +2 / =0 / -0
70 383 engine.
$1200
This is a low mileage engine that I ringed and bearinged some time ago. It was a runner when I got it. Planned to use it in my 65 but went another direction. Bore taper was in spec. Original bearings were pretty nice. The stock heads were removed and a set of fresh 346 castings with viton seals and new valves were added.
The springs and retainers are not something I would use, but I have set mp 077 springs and retainers to include. Also have a few other odds n ends to include.
I installed new cam bearings but I'm not happy with the results. I used a cutter cam and they look rough, but a new cam turned fine. I believe I have another set i can include.
I have a deep sump oil pan and pick up, timing cover, Erson hyd cam and I'm sure some other stuff I will include.
I've kept it coated with fluid film, and kept it bagged but have moved a couple of times so I would clean it before use.
Will trade for Mopar 65-70 b body 8 3/4 sure grip rear end, gen 3 hemi or similar condition 360
Located in Stoughton Wisconsin
Does it have the ID # on the side rail pad ?
70 383 engine.
$1200
View attachment 1355494 .View attachment 1355495View attachment 1355497
View attachment 1355494 View attachment 1355495View attachment 1355497
View attachment 1355498 View attachment 1355499
What is the Vin Number Please?
