Inline check valve
Houle #382
3:56 AM
Hastings NY
Just wondering if anyone is running an inline check valve to stop the carb from draining back into the tank. After sitting for 4 or 5 days I have to sit and crank for what seems forever before it will start so I'm thinking of putting in a check valve and just wondering what's a good reliable check valve and where are you locating it.
IMO......The carb inlet / floats are the check valves as well as the fuel pump discharge has a outlet check valve to prevent EXACTLY that. There is no need for additional hardware.
BOB RENTON
The only way it's draining back is if your pump checks are leaking, or you have something in one of them!
This has been discussed recently in another thread. Before installing a band-aid that may not produce any results, check things from front to back such as fuel line hose clamps, pump pressure, filter, pump pushrod if big block, etc. Like @dadsbee I can let mine sit for 1 week or 6 weeks and it will start by the first, or second try at the most. If you're running a Carter/Edelbrock 4bbl I can't see how fuel would be "drained" back to the tank once the bowls are filled.
The carb cannot drain back to the tank.
The fuel level in the carb is not high enough to sit at the needle seat to draw a siphon on the bowl. Some pumps do have tiny holes in the check valve button to allow vapors to bleed off so the fuel line could go empty to the pump bowl. But the gas in the carb bowl evaporates causing your hard start. As other have stated above and in other post.
A solution put a switched electric pump inline. You switch on the pump to fill carb then turn it off. You need an electric pump that your mechanical can draw fuel through elec pump. Rotary elec pumps won't work, Holley and Carter.
Yeah that's my thinking as I already have a Carter external inline pump but trying to find a good place to mount it close to the fuel tank is almost impossible as there is no room on a 68 Corornet RT. What I did thou is I did buy a check valve as I wanted to try it before getting into a pump. Lots of replies are saying the check valve will not work. Here's what I did I installed one in the fuel line between the carb and my mechanical fuel pump closer to the carb. Started the car up to check for leaks and everything looked good and took it for a ride to get the temp up to normal operating range ( 180 degrees ) put the car back in the garage and let it sit for 7 days without starting it. Got into it yesterday hit the gas pedal once to set the choke then hit the key and in less than 2 seconds she fired right up so the check valve did what it's designed to do, I'm sure I'm going to get lots of response about the valve but hay it worked I didn't have to sit cranking it for 5 minutes to get it started. I still do have the option of installing the pump and using a switch to run it for a minute or so but for right now I'm happy with the outcome of the valve and it only took 5 minutes to install.
Good to hear that it worked for you. What check valve did you use?
GREAT that it worked!
That said, it's a band-aid on something else that is wrong. Did you try pulling the fuel line off the carb and blowing back through the fuel pump to see it it's internal check valves were fawked??? I have 5 old Mopars. They can all sit for months and start on a couple of taps of the pedal and 2 cranks max.
Interesting, and neither of my two will do that. I have to crank the heck out of them after setting a month. One with a Edelbrock and one with a original B&B.
