69a100
- 10:35 AM
- Aug 22, 2012
This isn't a car discussion but it's a subject we're all too familiar with! This is the bottom of my garage/basement overhead door, as you can see there's some issues that I want to address before putting bubble wrap on. The first 3 pics are from the inside bottom, as you can see the center has been eaten through. The rust has crusted the nut/bolts that holds the weatherstrip trim piece so it's lookin like those will have to get ground off, and have to use sheet metal to fab that piece that holds the weather strip as that's pretty trashed.
I have some POR-15 left over from a different project, should I use that or get some SEM rust-mort and go over it with that? Maybe do both? It doesn't have to look good, just better and stronger than this. What do you guys think?
