SOLD Chrysler 3.23 Ring and Pinion Gear Set for "489" Carrier
roadrunnerh
9:36 PM
Pittsburgh, PA
Feedback: +5 / =0 / -0
Up for your consideration is this original 3.23 Ring and Pinion gear set. These will only work in a "489" case.
(1 7/8" tapered pinion shaft). Dated 4-27-68. These look good to go. $150 OBO Plus shipping from Pittsburgh, PA 15218. Thanks!
Apologies for "commenting" on a for sale ad but - I count 11 and 42 on the teeth? That would be something other than 3.23:1?
Something is weird there - the pinion should have 13 teeth?
Yup.... 43 & 11 gives you a 3.9 gear... 43 & 13 gives you 3.23.... That pinion doesn't belong with that ring gear.... And probably won't even mesh properly...
This was a gear set that came with a sure grip unit I bought this summer at Carlisle. The ring was attached, a yoke and pinion gear was in the bucket with the SG with ring attached. If this is the wrong pinion I'm glad someone saw it, I certainly don't want to mislead anyone here.
