How many parts and pieces are in a complete 440 V8 engine?
Kern Dog
Life is full of turns. Build your car to handle.
10:04 AM
Granite Bay CA
Think about it. How many parts including the block, heads, gaskets and hardware....
100 parts? 200 ?
This is merely for the purposes of conversation.
300 ?
"aint nobody got time for dat"
how's my grammar?
my guess would be 190
Got it ! 1,395,286.... plus a few leftover after it's put together (... now WHERE do these go ? ... )
Posted it at 2:09a......wife kick you out to the chicken coup??
The question that needs answered is "if I quote you and you get a notification, does that notification go away if I delete the post?"
Well here is a start to the question asked. I think I have a lot of this correct. But I know I missed a few items. I was bored... So here ya go. Revised for easier counting... THIS TOTALS OUT TO BE 597 give or take a bolt or 2.
1 oil slinger
1 cam gear bolt or 3 depending on cam.
1 cam gear washer
1 crank bolt
1 crank bolt washer
1 cam single bolt or 3 bolt.
1 timing chain
1 rear cam block plug
1 oil dipstick 2 piece
1 pickup tube for the oil pan
1 distributor
1 Bronze bushing for the intermediate shaft.
1 distributor hold down
1 distributor hold down bolt
1 distributor gasket/ O-ring
1 distributor cap
1 rotor button
1 carb gasket
1 carb
1 set of points or 2 depending on the distributor
1 throttle bracket/kickdown
1 intake
1 valley pan
1 crank
1 crank keyway
1 rear main oil seal retainer
1 front seal for timing cover
1 harmonic balancer
1 flex plate
1 water pump housing
1 water pump
1 water pump housing neck
1 thermostat
1 thermostat housing gasket
1 water pump gasket
1 oil pump to block gasket
1 oil pump shaft o-ring
1 fuel pump
1 fuel pump to block gasket
1 oil pump
1 oil pump intermediate shaft
1 coil
1 coil bracket
1 timing chain cover
1 timing chain cover gasket
1 coolant temp sender
1 Oil pressure sender
1 starter
2 heater hose pipes screwed into the water pump housing.
2 head gaskets
2 fuel pump to block bolts
2 oil seal retainer bolts
2 cross bars for valley pan
2 valve covers
2 dowel pins for transmission alignment
2 starter bolts/nut
2 cast iron heads
2 valve cover gaskets
2 water pump to block gaskets
2 water neck to housing bolts
2 timing gears
2 coil bracket bolts
4 fan to water pump bolts
4 Intake gaskets
4 carb studs
4 carb bolts
4 dowel pins for head alignment
4 oil pump top block bolts
5 cam bearings
5 main caps
6 crank pulley bolts
6 flex plate bolts
6 block freeze plugs
6 block plugs
6 cross bar bolts for valley pan rails
7 water pump housing to block bolts
8 piece rear main seal
8 timing chain cover bolts
8 wrist pins
8 rods
8 pistons
8 spark plugs
8 head coolant plugs
8 bolts for intake
8 washers for intake
9 spark plug wires including coil
10 main bearings
10 main bearing cap bolts
11 flat washers
11 lock washers
12 valve cover bolts
12 exhaust studs
16 lifters
16 push rods
16 rod bolts
16 rod nuts
16 upper and lower rod bearings
24 pieces for oil pan including bolts, gasket and oil plug on the pan.
32 valve stem keepers
36 parts in a rocker arm set. "stock setup"
40 rings
48 valve springs, retainers and valves as a total number for both heads. Not taking dual springs into the list.
68 head bolts and washers "ARP"
Looks good, piston ring pieces should be 40
What is the total number? I dont have time to add it all up, Im at work. haha. I was going to guess around 400.
Hell, I haven't added it up yet. I was trying to think of more items that I may have missed.
