BeepBeepRR
Overlooked but now added. Hell I counted the timing chain and everything that touches it but forgot to add the cam lol.I would say you're doing darned good, but where is the Camshaft ?![]()
I was merely joking.Now you are making it complicated. Lets just say a Stock Long Block.
Well here is a start to the question asked. I think I have a lot of this correct. But I know I missed a few items. I was bored... So here ya go.
36 parts in a rocker arm set. "stock setup"
16 push rods
2 head gaskets
32 valve stem keepers
16 lifters
1 cam single bolt or 3 bolt.
1 timing chain
2 timing gears
1 oil slinger
1 cam gear bolt or 3 depending on cam.
1 cam gear washer
1 crank bolt
1 crank bolt washer
8 timing chain cover bolts
1 timing chain cover
1 timing chain cover gasket
5 cam bearings
1 rear cam block plug
1 oil dipstick 2 piece
24 pieces for oil pan including bolts, gasket and oil plug on the pan.
1 pickup tube for the oil pan
16 rod bolts
16 rod nuts
8 wrist pins
16 upper and lower rod bearings
8 rods
40 rings
8 pistons
68 head bolts and washers "ARP"
2 cast iron heads
1 distributor
1 distributor hold down
1 distributor hold down bolt
1 distributor gasket/ O-ring
1 distributor cap
1 rotor button
8 spark plugs
9 spark plug wires including coil
1 coil
1 coil bracket
2 coil bracket bolts
4 carb studs
4 carb bolts
1 carb gasket
1 carb
1 throttle bracket/kickdown
1 set of points or 2 depending on the distributor
8 head coolant plugs
12 exhaust studs
48 valve springs, retainers and valves as a total number for both heads.
4 Intake gaskets
1 valley pan
6 cross bar bolts for valley pan rails
2 cross bars
1 intake
8 bolts for intake
8 washers for intake
16 lifters
1 crank
10 main bearings
10 main bearing cap bolts
5 main caps
1 crank keyway
1 rear main oil seal retainer
2 oil seal retainer bolts
8 piece rear main seal
1 front seal for timing cover
6 crank pulley bolts
1 harmonic balancer
1 flex plate
6 flex plate bolts
1 water pump housing
1 water pump
1 water pump housing neck
1 thermostat
1 thermostat housing gasket
1 water pump gasket
2 water pump to block gaskets
7 water pump housing to block bolts
11 flat washers
11 lock washers
4 fan to water pump bolts
2 water neck to housing bolts
12 valve cover bolts
2 valve covers
2 valve cover gaskets
1 oil pump
1 oil pump intermediate shaft
4 oil pump top block bolts
1 oil pump to block gasket
1 oil pump shaft o-ring
1 fuel pump
1 fuel pump to block gasket
2 fuel pump to block bolts
Now we are getting nit picky. lol Lifters come in a box of 16. As far as the internals of components of like the carb, starter and oil pump... Well more nit picking...how many parts in each lifter? each valve spring assbemly? in the oil pump? i'll stick with 3
On my count, I was over 300.Well here is a start to the question asked. I think I have a lot of this correct. But I know I missed a few items. I was bored... So here ya go. Revised for easier counting...
1 oil slinger
1 cam gear washer
1 crank bolt
1 crank bolt washer
1 timing chain
1 distributor
1 distributor cap
1 rotor button
1 carb gasket
1 carb
1 intake
1 valley pan
1 crank
1 crank keyway
1 harmonic balancer
1 flex plate
1 water pump
1 thermostat
1 water pump gasket
1 fuel pump
1 oil pump
1 coil
1 coil bracket
2 head gaskets
2 cross bars for valley pan
2 valve covers
2 cast iron heads
2 timing gears
4 Intake gaskets
4 carb studs
4 carb bolts
5 cam bearings
5 main caps
6 flex plate bolts
8 wrist pins
8 rods
8 pistons
8 spark plugs
8 bolts for intake
10 main bearings
11 flat washers
11 lock washers
12 exhaust studs
16 lifters
16 push rods
16 rod bolts
16 rod nuts
40 rings
You don't open up a new oil pump and at least check the clearance on the rotor? I didn't either until I got a newly rebuilt engine in my shop because it lost oil pressure within 100 miles and dug in to see what the cause was and found a tiny piece of casting stuck in the bottom of the rotor against the end plate. The pump had .001" clearance and that's too tight. It should be .002 at minimum. Someone didn't clean the block before assembly. I thought it was a bit strange that the filter didn't catch it but it could have come from the oil pump itself. I made pretty good money on that job but it also taught be to debur that new oil pump too.Now we are getting nit picky. lol Lifters come in a box of 16. As far as the internals of components of like the carb, starter and oil pump... Well more nit picking...
... and you wondered why your engine wouldn't run....but forgot to add the cam lol.
