SOLD For sale 1968 charger with 440
Florida68
10:01 AM
Jacksonville, Fl
For sale is this 1968 Charger. Originally a 383 2 barrel car with factory AC. Engine swapped to 440 HP stamped engine with a 4 barrel. Engine sounds great, I dot not have the specs on it. 727 automatic. No rust on this car. Sheet metal work was completed and car was painted prior to me purchasing. Car sat for several years prior to me purchasing. I have added 4 new tires, new fuel tank, new fuel sending unit, new motor mounts, and car has a new radiator with it. The car runs and drives currently. Car is not in perfect shape, will need some work to complete. Does include extra parts With it. Asking $45,000. Please feel free to ask questions. Car is located in Fernandina Beach, FL, just north of Jacksonville.
Engine casting date, and the letter designation on the pad that is pictured?
There was sheet metal done under the rear window, one quarter was skinned, there is a very small square in the drivers front floor board, and yes the trunk pan was replaced. Sheet metal work appears well done. The letter code on the engine appears to be a J. Appears to be J 440 HP. The car also has a new starter.
Under hood pics? Is the hood bent in the corner?
The hood does have a bend in it and the hood hinge on drivers side appears damaged. There are 2 extra sets of hood hinges with the car. It appears the hood was struck by the engine when the motor mounts broke. As noted the mounts have been replaced.
I was asked about the spare parts with the car. There is a dual snorkel air cleaner, a factory 4 barrel intake, a extra set of heads, 2 oil pans, AC brackets, a new headliner in the box, and an extra set of headlight doors.
There is also new upper and lower ball joints with it, 2 sets of hood hinges, and 3 distributors.
