WTB Solid lifters
wondering why you want used lifters??Or are you looking 4 new only???? Comp cams sells new ones-#com-821-16--merry Christmas
I have a mp 528 solid that wiped a lobe. Ordered a similar Hughes cam, back ordered. Just seeing if anyone has a similar set up for sale. Would consider used cam and lifters if they’re matched. Or a set of new lifters. Just trying to save a little coin.
Merry Christmas
Thank you for the offer but it seems I’m not describing what I’m looking for clear enough. I don’t want used lifters unless they are matched to a cam. Cam and lifters together. Or a set of new solid lifters.
I do have a solid lifter set--lifters are all in order as to location on Comp cam--Cam is a 320 degree -535 lift --very strong performer--I would sell for $200 plus the ride--from 34982--was in my 70 Challenger running 10.5 @ 131 in the 1/4--
Hi. Is that a custom grind? I couldn’t find any specs. Do you know the duration @.050 and Lsa
I gave you the wrong everything on this cam-- its actually a Lanati cam--316 intake duration with 563 lift--and 326 duration and 563 lift on the exhaust--I do alot of these for myself and customers so its easy to screw up and I did--Its the Lanati cam not the comp cam--may be more than your wanting --let me know--Don
