Paul_G
- 9:46 PM
- Dec 24, 2013
- Surprise, Arizona
I put the 383 in my 69 Roadrunner until the Hemi is rebuilt. The 383 ran great when pulled out of the Charger. The Roadrunner ran great (no ignition issues) when the Hemi was pulled out, other than the Hemi needing a rebuild.
Doing the start up yesterday on the 383, the engine idles okay. When the throttle is opened the engine repeatedly backfires through the exhaust. Sounds like spark scatter. Check the plug wires, all in the right spots, checked under the cap, worn but no visual damage. Moved the base timing around from 0° to 20°, engine idled OK, backfiring on throttle opening continued. Put it back to 15°.
I tried this; connected the vacuum advance to manifold vacuum, as the advance came in and started to raise the RPM the engine started to backfire through the exhaust. Hmm?
It has an older MSD 6AL box, blaster 2 coil. Holley 670. And a tired stock electronic distributor.
First I swapped the Holley for an Edelbrock 600 I have. Still backfiring through the exhaust.
Then I swapped the distributor for a brand new one I bought from Mancini that was going on this engine anyway. Still backfiring through exhaust.
My next idea is to temporarily swap in a stock electronic ignition system to eliminate the MSD box.
Any other ideas welcome.
