- 1:25 AM
- Jan 18, 2017
Like most of Canada we are getting hit with cold temps. Minus forty, without factoring in windchill like a pussy.
Besides it being painfully cold to just be outside, weaknesses in our vehicles are suddenly brought to light. Plastic does not like to freeze.
If your battery is weak, or block heater doesn’t work, or you don’t run synthetic oil you will find yourself in need of a boost.
You go to open your hood. If the safety latch is behind a plastic grill you will break the grill when you put your hand in to open the latch. And because the opening is too small for gloves you will painfully freeze your finger tips. You manage to open the hood only to find that the hood support rod is held by a plastic clip, which now shatters from the cold. The cheap soccer mom booster cables that you keep in your vehicle are neatly coiled in the trunk. The plastic on the cable shatters and falls on the ground when you try to uncoil them, leading to the possibility of shorting red to ground. The red insulating cap on the battery terminal is frozen to the consistency of cast iron. You have to remove your mitts to remove it, and if you are wearing gloves thin enough to work in your finger tips freeze anyway.
Years ago some idiot suggested using a credit card to scrape frost from your windshield. It takes a few weeks to get a replacement card after yours shatters into a million pieces from the cold.
Music CD’s, unbreakable in the summer shatter like glass, as does the plastic case you are trying to put it in.
Plastic sucks, especially cheap plastic.
