70 beepbeep
I cant figure out how i access this bolt holding them to the fenders
BTW....Welcome to FBBO.....make yourself known over in the Welcome WagonI cant figure out how i access this bolt holding them to the fenders
Have you got a technique to share ? Last ones I saw the lens broke because the double-sided tape holding them was holding on so tight.You have to pop out the lens to access the screws to remove them from the fenders.
Exactly like the 69 Dart you referred to.I believe the lens screws are under the holder tabs. Once you have the assembly removed from the fender you should see them. Hope it's not like Moparmarks stated, like a '69 Dart rear lights, where you have to break the damn lens to remove the bezel from the quarter panel.
This is a '70 Dodge front marker... should be similar.
View attachment 1397632View attachment 1397634View attachment 1397635
Yes.Well....bugger me.....I was right in my first thoughts....a post I deleted suggest there may be two variations now.
I found an old rear marker light that I pulled from a 70 RR - assembled at the Los Angeles plant.
....or are the front and rears different?
Front & rear are different then.Yes.
Exactly, the screws are behind the lens on the front marker lights. You have to break the lens as there is no way to get them out without damage. I just came short of damaging a fender before I found out.Front & rear are different then.![]()
It's been 24 years since I last pulled one out. Memory fade....that's my excuse.Exactly, the screws are behind the lens on the front marker lights. You have to break the lens as there is no way to get them out without damage. I just came short of damaging a fender before I found out.
I'm talking about front fenders on a 70, the pictures look like the 70 rear quarter markers. Amber for the front not red.My '70 is like that, remove the nuts and the light comes out easy. Mine was built at Lynch Road in January.
You are correct, I remembered wrong. I deleted my post.I'm talking about front fenders on a 70, the pictures look like the 70 rear quarter markers. Amber for the front not red.
I was going to type this.. This your best bet if trying to save the lens..What about a heat gun to soften the two sided tape. I know on the rears a soak in hot water is possible once removed.
