Wietse
Hey guys,
I've seen many video's of engine dyno's (i.e. Nick's Garage) where engines with a similar cam or bigger compared to mine can idle smooth and have a decent vacuum. (my cam is 238/244 @ .050" .572/.576" lift and get 7-8" vacuum at 900 rpm idle)
Only realizing that those engines on the dyno are not pulling any other auxiliary equipment other then the oil pump.
So I wonder how much power would be drawn from the engine at idle by the oil pump, radiator fan, cooling water pump, alternator and power steering pump?
My 440 has an HV oil pump (80 psi @ cold with 20W50), high flow 440 source cooling water pump, fixed 18" flex fan, 90 amp alternator and a saginaw power steering pump.
When the engine is at normal operating temperature it settles down and runs ok-ish, likely less load demand as the battery is charged, engine oil and power steering oil are warm and therefore easier to pump.
Obviously it is not an option to remove any of them, though I do want to test this by removing the belts and run the engine for a bit to see what will happen.
Could all these together add enough load on the engine to affect the idle quality?
Any thoughts?
Before you ask, I tried everything already that is known to man to figure out why this relative small cam causes such poor vacuum.
Vacuum has been same with 2 different carbs an currently on EFI, no vacuum leaks, cam is set as correct, ignition advance does not matter sh*t, new timing chain, pressure tested intake manifold (no external leaks and no leaks towards crankcase)
Any thoughts?
