Mystery crank?
Jim914
3:29 AM
Sulphur La.
This crank was in the boxes of parts I acquired. All I know is the hemi has 8 bolts at the flywheel. Rods and mains are std hemi. What set up is this on the back of the crank? No ridge for flywheel or flex plate.
Is there a application for this set up?
I was thinking industrial too but an industrial engine still needs a starter. Without some sort of wheel on the crank for it and no way to keep the wheel centered, how would you start it? Somebody with more knowledge will surely chime in.
The ring gear is mounted on the torque converter or flywheel.
Still need a register to center the TC and that crank doesn't have it.....at least not for the more modern times......60 years ago?
I agree, but here we are with no register on that crank. They had to start it somehow?
I thought the olden days chryslers didn't have registers. I don't know much about the real old stuff.
Me either lol
more pix than just the flywheel end may help immensely.... does it have a double keyway on the other end??
Which would lead to the question; how were they bolted together?
Well, I think you needed to pick up a can of Band-Aides first, which is why they changed it to the other way around. :poke:
I think I have an early 413 crank here....I'll have to dig it out and see what it looks like, but I think more pix from the OP may reveal what KernDog told him to start with.
I thought it looked a bit to crummy and factory to be an aftermarket tf crank..who knows.
But mentioning it has Hemi dimensions...(or 440, or 413, or RB383 , or 426w) can throw people off.
Here's to hoping it's it's the fuel crank :drinks:
So, as I was digging for the early production crank..... I stumbled across this Velasco Hemi Crank, supposed to once be a $3,000.00 piece, now, not so much.... Should answer the OP's question.
Is it forged steel, or billet? The alcohol and fuel cranks I've had were always billet, had extra rod and main clearance ( .002 under), and Lots of Mallory in em . (and no register, and lots of cracks.)
