need mechanic recommendation for my daughter in Phoenix
Billccm
10:05 AM
Tucson
Hello:
My daughter recently took a job in Phoenix and moved away from Tucson. We are proud of her and glad she is starting out a career!
Anyhow, her Fusion turn signals went into 'hyper flash', and it seems it is probably just a bad bulb. Problem is my daughter has no tools and no car skills whatsoever. Looks like you have to pull 6 'Christmas Tree' fasteners to get the panel off to access the rear bulbs.
She is located near 12th and Highland in Phoenix. If you know of a shop you can recommend to help her, or if you are nearby and want to make an easy $50 let me know.
Thanks, Bill
Bill, if you do not get a reply google search for a parts store near her.
Many of them have some pretty decent guys working that would sell her a bulb then go out and install it.
Mabey you could call ahead and explain things.
I'm like you though and would think a local member there would help out.
My neighbor manages an honest shop not far away. 25th street auto. Behind Taco Bell at 25th street and Indian school. They do the work I don't want to do on my late model cars. When my Daughter comes in from California she tries to get her car worked on there, Bill takes care of her.
Thank you for the recommendation. I want her to start a business relationship with a local shop. I appreciate this and I think this will be a good repair to try out.
I want to thank you for the recommendation. My daughter had an oil leak and it was just the valve cover gasket. They took good care of her and made her feel comfortable discussing the issue. Appreciate the information. Take care.
Faithworks Transmissions and Auto Repair LLC 52820 W. Jersey Dr, Maricopa AZ 85139, 520-635-8257. They helped my daughter out moving from CA to FL when the trans took a ****. Samuel bent over backwards to help her, more than I would have expected a shop to do.
News Flash, there are actually a lot of shops that try to do the right thing... But there's also always gonna be crooks... That's true in every part of life...
True, but I have had personal experience with this shop, and worked with me over the phone to get my daughters van back on the road.
Not for a minute trying to imply they are anything but stand up guys.... And between them & the shop HemiBeep suggested I'm sure she's in good hands.... I'm just pointing out there are more shops with good intentions than there are crooks...
