SOLD 1971/72 roadrunner steering column with wheel. (Black)
capt46
11:09 PM
NY
Feedback: 2 / 0 / 0
Floor shift unknown condition blinker switch clicks when used. No bearing on shaft shear pins are gone. $300
Plus shipping
That's not a 1970 steering wheel. 71 or up probably.
Unsure how to tell?
thank you updated.
71-2. They didn't have a lower bearing. 70 doesn't have the key release lever on the collar or that steering wheel..
Please help ID LOL I APPRECIATE IT
Unsure how to tell?
The column may be a 70, but the steering wheel has buttons for the horn which they did not in 70. Also the deluxe wheel in 70 was pebble grain and I'm not referring to the wood grain wheel. Hope this helps.
Thank you removed from long time storage
Thank you! The flasher also says hazard?
So it’s 71/72 ?
No problem.
Next question will be is it for power or manual steering? You said the shear pins are gone. Does that mean you can move the lower shaft in and out?
Looking at the splined hole on the coupler it looks like it is for power but it best to measure it. Power has a smaller hole than manual.
Tell me what to do yes the shaft is free. Whatever it takes thanks again
I would bet on power steering
