Looking for pictures or images of a 71/2 Plymouth Air Grabber hood
Ben Mowery
2:00 PM
Indianapolis, Indiana
I am currently converting a Satellite hood to an air grabber hood for my 71 GTX. I found the template for whole locations, but I am looking for an image of how much the front brace gets trimmed as well as other inside modifications for the hood to allow it to look somewhat correct. I know I will need to clearance around the holes for the bell nuts and such. There was a post here that was a little dated. I found it about a month ago, but I can remember what I searched. Any help would be appreciated. TY.
While this subject is being revisited, I’ve been looking for quite some time to find a cutting tool to accurately reproduce the attaching nut access holes in the hood frame (because of the multiple contours). I always felt that a hole saw would be ideal, but couldn’t find one smaller than 1” diameter, but just yesterday I found a bi-metal hole saw kit at harbor freight with a .750” saw, which is what’s needed, so I’m crossing my fingers this thing will do the job. Just thought I’d throw that in since you’re looking to do the same thing I am doing.
Ben, I went thru the ordeal. I made my hood into an Air Grabber. I bought the kit from Stinger.
The 4 rear holes for the bell nuts are huge - I think they need to be at least 1" in dia. but double check before you drill.
I posted my work on the Road runner nest forum.
Startin to work on the Clone Runner (it's PAINTED!) - Page 13 - Road Runner Nest
It starts on page 13 where I cut the hole in the hood.
Then jump to page 22 to see the work required for the Stinger setup.
*note* I'm not using any of the under hood Air Grabber components due to the height of the intake I plan on using.
If you go thru the rest of the pages you will see how I keep the air door in the open position.
