70bigblockdodge
Hear I thought the track was being helpful.7.22 is et at the first mph clock, at 594 feet. (Correct answer).
Edit: roughly .5 sec to cover the last 66 feet.
Makes sense after you point it out.
This is great!You can use the paper method on DOT tires.
Start high pressure 28 maybe and on a really smooth surface (garage concrete floor is great) try to put paper under outside edge. Keep lowering pressure until the paper does not want to go under anymore (shoulder of the tread is on ground). That's about right pressure and you can vary a couple pounds in each direction.
Uncle Tony did a video on this if you need a visual to understand my poor wording.
More air pressure my give you some tire slip if your having trouble getting up in rpms out of the hole. Fine line before it breaks traction and spins, but that's half the fun is experimenting.
Well, I just learned something, thanks.7.22 is et at the first mph clock, at 594 feet. (Correct answer).
They are!Hear I thought the track was being helpful.
What's your car's combo? Rear end gear is pretty important for 1/8 mile racing. In the 1/4, if you don't have enough gear but a good top end, you can usually run past the opponent on the top end. Hard to do that in the 1/8 mile.I'm glad I posted this
I've learned quite a bit
440 10.7:1 compression .509 Purple shaft Cam Eddy RPM aluminum heads Eddy Torker II intake Thumper 850 billet CarbWhat's your car's combo? Rear end gear is pretty important for 1/8 mile racing. In the 1/4, if you don't have enough gear but a good top end, you can usually run past the opponent on the top end. Hard to do that in the 1/8 mile.
What is your shifting RPM and what RPM are you crossing at? I'm thinking you could probably use more gear and maybe a lot more but if you are also using your car on the street, you probably won't want to...440 10.7:1 compression .509 Purple shaft Cam Eddy RPM aluminum heads Eddy Torker II intake Thumper 850 billet Carb
727 auto with 3000 RPM Stall
8.75 rear end with 3.91 gear Mickey Thompson ET Street R radials P255/60r 15 (27")
Car weighs 3800 pounds
Since this was my first trip with this engine I was shifting at 6000What is your shifting RPM and what RPM are you crossing at? I'm thinking you could probably use more gear and maybe a lot more but if you are also using your car on the street, you probably won't want to...
| 60 Foot | 1.66 |
| 330 Foot | 4.81 |
| 660 Foot | 7.55 |
| 660 MPH | 90 |
| 1000 Foot | 9.93 |
| 1/4 Mile ET | 11.97 |
| 1/4 Mile MPH | 110.70 |
| 60 Foot | 1.70 |
| 330 Foot | 4.91 |
| 660 Foot | 7.72 |
| 660 MPH | 88.05 |
| 1000 Foot | 10.15 |
| 1/4 Mile ET | 12.23 |
| 1/4 Mile MPH | 108.30 |
