- 10:47 PM
- Dec 4, 2009
- Pasadena, Texas
Looking for some info about the installation of one behind an 833. Downfalls vs upside etc. Not really wanting to modify the floor either.....
Mine did the same so I put a switch on the hot line from the battery. Only have to reset the brain every once in awhile. Incidence decreased with cleaning up the ground I can tell you.Since the 1966 is similar to the 1970, I can comment.
Mine fit fine. They tell you that you’ll need a dimple to the tunnel at 10:00 and 2:00. That is all. What can be a problem is the clearance for the speedometer drive. Without a 90 degree adapter, you have to cave in part of the floor so the cable isn’t in a bind. My 90 degree adapter broke and they claimed to not have any spares. Maybe they felt no obligation to sell since I bought my GV unit used. This was 2013. Maybe things have improved.
The unit did work though. The electronics have been improved from what I hear. Mine would stick in OD even when I came to a stop. I only wanted the unit for a fourth gear, not gear splitting.
I've been researching this for an A833 as well. I have a GV behind a Turbo 400 in a GM car. Love having the overdrive. Regarding the A833 I looked for UTube videos as I'm wondering what thei GV tail shaft replacement requires. Wondering if the GV tail shaft has a bushing for the output shaft as well. Wondering how short the driveshaft will need to be after GV tailshaft and OD unit is installed because it looks like it will need to be pretty short and the pinion angle might need to change. Might be time to talk to GV. They have been really helpful in the pastLooking for some info about the installation of one behind an 833. Downfalls vs upside etc. Not really wanting to modify the floor either.....
Hey, it's only about 3 months old. Old posts are usually much older lol and thanks for posting the info!Old post I know, but I told Cranky I'd post it for others.
Not needing the control box is good to know. I've always been 'in tune' with my cars and always shut off the OD's in the 'modern' iron when I was running around 35 anyways....until the switch went out on the 95 Dakota for the second time so I just wired it where it was on all the time. It still shifts out when it gets slow so I never worried about replacing the factory switch which is pretty much extinct now and didn't bother with using a toggle switch. I'm not so hot with wiring since I'm shade blind.And since you got a 833, you don't need the control box, you can wire it up so you can manually engage it. The only down side to this is the control box detects your speed and won't allow engagement under a certain speed (35mph I believe). Under that speed, the pump inside the unit doesn't generate enough pressure and will lead to premature wear, so the control unit automatically disengages it if you forget to disengage it yourself.
Also, you may see used GV units on CL or Ebay, they were actually designed for motorhomes I believe, so sometimes you'll see them for sale for around a grand. By time you buy the unit, then a refurbished tailhousing, the control module, speedo sensor, etc, you're almost at the cost of a new unit.
