68.Charger
I am trying to figure out why I have 1 dead cylinder. I have a 70 Road Runner with a stock 440 6 bbl. and #8 cylinder won't fire.
I pulled the XR5 spark plug for #8 and its very black and has build up all over it. The rest of the spark plugs look nice with a clean tan appearance on the porcelain. I did a compression check and its about the same as the other cylinders ~170psi. I pulled the valve cover and bumped the engine over and the valves seem to be moving the same as the other 3 with nothing obvious looking out of whack. With the engine running I can pull the spark plug wire for #8 and the rpm's don't change - but they will drop for the other plugs. When I am removing or inserting the #8 plug wire from the cap, I can see and hear the spark arcing to the plug wire brass end piece. I replaced the plug with a new one and no change. If I pull the plug and ground it with the spark plug wire attached it is arcing across the tip to ground.
So it seems I have compression and spark so why won't it fire? I used a thermal gun to check the exhaust manifold temps from a cold start and sure enough number 8 lags way behind the other 7.
What am I missing?
What am I missing?
