Assembly Sequence
Moparfiend
2:04 PM
HOT
Hi I am almost ready for paint and starting to think down the road. Wondering what a good assembly sequence looks like after paint. Doors hood and trunk are off, car is completely disassembled except drivetrain.
Suggestions welcome!
If you haven’t been following my build is here:
1970 Plymouth Sport Satellite from Junk to......
I am putting a 70 Charger back together that was totally apart
The main body is in primer and ready for final paint
I painted the inside of trunk inside of interior inside of all window openings and firewall and inner front end area with no sheet metal on it yet
I plan to get the car all back together and running before I put the front end on ( no leaning over the fenders )
Get the glass all back in without the chrome trim on and interior together then tape it up good to paint the rest before bumpers lights and grill go in
I know my question is a bit vague. This is waht I was thinking.
1. After paint I would keep the doors and windshield off. Get all the wiring and dash steering column etc installed.
2. Get the rear windows and hardware in.
3. Headliner dome light
4. Carpet
5. Seats
6. Doors
What else am I missing lol??
Get the head liner in before front and back glass makes it easier
Great input! That headliner is going to be a PITA I am sure. Have all the cross members but didn’t number them when I removed them….
I found it from Resto Rick, just cut and paste.
Here's a sequence I've been working on to post on my tech board...
ASSEMBLY SEQUENCE:
(some variation with different body types)
(from bare painted body shell)
Spray radiator saddle blackout
Rocker panel pinchweld blackout (if applicable)
Front frame rail side blackout (if applicable)
1. trunk weatherstrip
2. body rubber bumpers
3. trunk latch mechanism
4. hood latches & release mechanisms
5. main body brake & fuel tubing
6. fuel tank & fuel hose connections
7. emissions tubes & hose connections (if applicable)
8. inner cowl insulation pad
9. firewall insulation pad
10. swing pedal(s)
11. brake booster (if applicable)
12. master cylinder
13. defroster duct
10.kick panel insulation pads
11.LH vent box (if applicable)
12.E-brake pedal assembly & front cable
12. heater box assembly
13. wiper mechanism
14. wiper motor
15. cowl vent screens (if applicable)
16. accelerator pedal & cable
17. dash assembly (completely assembled outside
of car including instrument cluster, dash pad, glove
box liner, radio, speaker, wiring, etc.)
18. Vent pull cables, defroster & vent cables
19. windshield
20. proportioning valve & metering block (if applicable)
21. firewall brake tubing
22. starter relay
23. forward lamp harness
24. engine harness
25. starter wiring
26. washer bottle & hoses
27. ballast resistor
28. voltage regulator
29. horn relay (Bbody cars)
30. horns
31. heater hoses
32. headlights
33. fender inner splash shields (front & rear of wheel)
34. rear suspension stop bumpers
35. rear seat belts (some bolt tips get undercoating)
36. rear shocks bolted in at top only & compressed
37. grille & headlight doors
38. front bumper
39. front valance (if applicable) with directionals
40. front & rear side marker lamps
41. rear bumper
42. radio antenna
43. fender emblems (if applicable)
44. rear of fender splash shields
45. undercoat wheelwells
46. exterior emblems
47. windshield & backlite stainless trim
48. windshield wiper arms & blades
49. other exterior trim
50. taillights
51. mid body/rear lamp wiring harness
52. dome lamp wiring harness
53. shoulder harness clips (if applicable)
54. rear grip strips (Bbody)
55. headliner
56. roofrail c-channels
57. roofrail weatherstrips
58. windshield & backlite moulding clips
59. windshield & backlite
60. upper control arms on body
61. fuel hose clamped on body side fuel tubing
with keystone crimp clamp
63. install rear leaf springs front only
64. position rear end housing on springs
65. loosely fasten u-bolts
66. lift rear axle into position and install shackles
67. connect e-brake cables
68. connect brake line tubing & hose
69. DRIVETRAIN SUBASSEMBLE
a. K-member
b. engine
c. carb(s)
d. starter
e. alternator
f. fan & fan clutch
g. power steering pump (if applicable)
h. belts
i. motor mounts
j. trans & related hardware
k. lower control arms
l. strut rods
m. center link, idler arm, tie rods
n. steering box & pitman arm
o. fuel pump and tubing
p. fan blade
q. radiator hoses
70. drop body onto drivetrain subassembly
71. connect heater hoses
72. install trans crossmember
73. install driveshaft
74. connect shift linkages
75. install z-bar (if applicable)
76. connect clutch linkage (if applicable)
77. plug in electrical connections to engine
78. position fan shroud over fan blade
79. install radiator & connect hoses
80. connect trans cooler (if applicable)
81. bolt up fan shroud
82. install torsion bars
83. install exhaust system
84. install rear valance (if applicable)
85. set car on the ground
86. install & align door and quarter glass
87. install steering column
88. install carpeting
89. install seat belts
90. install quarter interior trim panels
91. install rear seat
92. install console (if applicable)
93. install front seat(s)
94. install trunk mat
95. install spare tire
96. install bumper jack
