Best oil for 440.....
FLARunner
6:50 AM
Miami, FL
I've had my 68 Road Runner for about 3 months. I'm the 3rd owner of the car (to my knowledge.) I don't know what oil was previously used, and I cant get in touch with the previous owner, and it's about time for an oil change. The 440 is out of a 66 Dodge Coronet. What is my best choice for oil? Any and all help is much appreciated!
10-30 with Zinc, if you beat on it 10-40 and if you redline it constantly 20-50(warm weather only)
Any name brand oil that contains Zinc/ZDDP would be preferable, but you can use a zinc/zddp additive if necessary. I like redline, and Schaefer’s for the spendy stuff, but castrol and valvoline make high zinc options that are more readily available.
No need for an extra additive when using Valvoline VR1 in either 10w-30 or 20w-50.
Yup, all good oils....I would not go synthetic bled though.
Many like the 10-30s and 10-40s
shell rotella and another diesel have the zinc which is a good lube
I use diesel 15W40 in my 413.
Rotella? I was using that in everything but now everything I have have roller cams. Their oil doesn't have much ZDDP if any these days.
I read years ago that Shell reduced the ZDDP by a pretty good number.....
Same as a flat tappet chevy 350, Ford 351, Olds 455, a 440 doesn't take "special" oil. Assuming 1st engine you've changed oil on?
I like Rotella 10/30 T6 full synthetic in mine. Everyone has their preference.
Amsoil Z-rod 10-40 (has Zinc additive). I was turned onto Amsoil by my good buddy Dennis H, who runs it in his yellow Coronet R/T. It's been good stuff and now I also run Amsoil trans fluid in my 727 and Amsoil Dot3/Dot 4 brake fluid as well.
Yes, they reduced it when the class 8 diesel trucks went to DEF for emissions control. I switched to VR1 after the change.
Is the cam in the 97 5.9 diesel a roller?
Did all the above answer your question FLARunner? :D
Ever heard the expression that opinions are like ********?
Well there you go. My vote goes with Ski's response.
I have always run straight 30W and add a bottle of Lucas break in additive at every oil change.
Another "oil" thread.
Yep, ask 100 people and get 100 different answers…
The old Direct Connection B/RB Performance Bulletin recommends high detergent 30W, which has worked very well for the 40+ years I’ve run big block Mopars.
