- 5:12 PM
- Jan 11, 2022
- Fredericksburg, VA
The drivers side door glass sags down leaving the gap shown in the picture when I close the door. The vertical chrome trim won’t seal against the quarter window. The window frame in the door is clearly sagging because I can pull up on the rear of the frame even after rolling the window all the way up. I also wonder if there could be an alignment issue with the quarter glass, but it doesn’t appear to sag in the channel. Any thoughts on what the source of this problem might be and how I could fix it before I pull the door panel apart and investigate? Thanks.
