SOLD 18 spline Aluminum 4 speed transmission $2500
LOCK and LOAD
10:11 PM
Channahon ILL
Feedback: 1 / 1 / 0
Hi I don’t much about this trans , came from estate. Was told used for racing. And rare because its Aluminum was also told weren’t a lot made. Selling for friend Like to get $2500. Also have a cast 18 spline. Trans $1900. It’s from a 69 trans I took the side plate off looked good. If anyone knows about the aluminum transmission please email me. Like to know more.
It could be an old Direct Connection over the counter piece. I ran one for years in my Road Runner. Check to see if the case is sleeved on the cluster gear shaft. If so it's a DC case and probably has slick shift cut synchros in it.
this trans the aluminum trans is 18 spline someone said they used for racing I even counted. twice 18 spline
I'm not doubting that, just something I don't know about. @Outlaw525 used one, he should know.
That aluminum case has the strengthening gussets unlike a standard OD. The Passon Performance 833 book describes transmissions/components in depth.
is there an groves in the input shafts of either trans ? it would be were it rides on the crank bushing area .
The aluminum 4 speed was available as a complete unit or you could buy just the case and tail from Direct Connection. The case is different from the OD cases because of the strengthening ribs
