CoronetDarter
Yep, I did it this time. Usually when I break something on car, after a bit of troubleshooting I figure it out, a lot of times by pure luck. In this case, my 69 Coronet has a no crank issue and after the better part of 4 weekends including six hours today I'm still at square one.
First the back story. I had the IP out as the speedo needed rebuilding. The speedo cable was resting on one of the header tubes, melting the outside jacket and essentially welded it to the cable. The sudden resistance burnt/broke the speedo mechanism. Got the repaired speedo back from JC Auto Restorations (which I highly recommend BTW) and I got ready to reinstall. While waiting on the repair I replaced some of the LED lights in the PCB. With just the PCB resting on the steering column, the circular wiring harness plugged in and a jumper running from the RTE voltage limiter to ground not only was I able to test the LED lights but actually started the car. Two weeks later I install the speedo into the IP, secure the PCB to the rear of the IP, plugged in the circular harness, and reinstalled the IP into the dash frame. At this point I tested the LED lights again in Acc mode, go to start the car just for S&G before I get too far, and nothing. No crank. Accessory and Run both work as the lights go on and the electric fuel pump starts up. Turn to Start and its like someone removed the battery. In Run, there's nothing when I jump the Batt --> Sol terminals on the starter relay. There's 12.94 V at the yellow wire at Start, 0V at SOL. Seems pretty straightforward, I get a new starter relay from Ehrenberg on E-bay, same result. Next (which I should have done originally), I swapped the new starter relay over to the Dart and it fired right up. So now the new starter relay is in back in the Coronet.
