Emergency brake Spring - help
Bats5
2:26 PM
Milton ON
Hoping someone can help. i am rebuilding the entire brake system on my 1969 Satellite. i took the emergency brake pedal assembly apart to change the cable. the one time i did not take a picture before doing so, and now i can't figure out where the spring that pulls the pedal back up goes. Not the spring for the relase hanlde mechanism, but the e-brake pedal itself.
I looked all over the internet and searched this as well with no luck. Any help or a picture would be great.
Thank you in advance!
There is none. Its all in the cables.
that would make sense, seeing that i could find no picture or indication in the service manual. means I have an extra spring that i have no idea where it goes ;).
thank you.
thank you.
Post a picture of the spring in question and maybe someone can tell you where it goes.
Hope you have better luck than I had! Ordered parking brake cable for my RR twice and
both were too short. Can't figure out why the cable from brake lever to connection to the
rear cables is about 2-3 inches too short. Ordered the second one thinking the first was wrong
but same problem. Anyone has an answer? Last one was from Dorman Part #C92323.
