Viewsonic
Hello, so long story short. I installed a 383/727 from a 68 fury into a 69 satellite wagon. I hooked everything up the best i could following wiring diagrams from mymopar. According to the diagram, i am 95% sure i got it hooked up right, aside from the diagram showing two DBL wires going from the ignition ballast to the IGN on the VR (my car only has 1 wires instead of two) However, when the car starts and idles for about a minute, the voltage regulator starts smoking and battery is reading 15.2 volts. No lights on, no radio, no heater, nothing powered up. I also fixed the wire going to the bulkhead from the alternator. (Spot P on the connector) because it was burnt up and had a poor connection. Cant tell you if that was before or after i hooked everything up. The VR is brand new, same with the ignition ballast. I dont know what i did wrong. Is there to be a ground at the VR?
I can supply any information as needed.
