John H
I have a 67 Coronet 440 with paint to match steel rims and hub caps. Is it possible to purchase trim rings for the 15" rims until I can afford Magnums?
67 darts did not have 15” rims. There will be 15” trim rings from newer years that should work and find out depth of your rims. Also check the diameter of the nubs for the center caps.Will the trim rings and center caps from a 67 Dart fit on these 15" rims? Any idea?
Thank you. Where would I find the information on the rim?67 darts did not have 15” rims. There will be 15” trim rings from newer years that should work and find out depth of your rims. Also check the diameter of the nubs for the center caps.
I would check the information on the rim to find out what you have. Then go to google to find out what would work. Is what I would do.
It should be by the valve stem, example JK, or other letters.Thank you. Where would I find the information on the rim?
i have 4 that are powder coated silver on the face. asking $250.00. these can be picked up at Carlisle, as shipping would be huge as you no probably know.I Like it. Anyone have any of these for sale?
