You cannot run two breathers!! You need one breather, and one PCV valve in order for it to work properly. If you remove the passenger side breather, you will likely find where you can break out a spot for a PCV grommet and valve. Don't forget to install a oil baffle under the grommet so it doesn't suck direct oil mist.So I may have to pull the passenger valve cover and get a breather cap also?
