FOR SALE Holley Carb List-6191 ‘71 383
Jimmy225
3:50 PM
Germany
I have a Holley Carb List-6191. I read that it’s not easy to get one. As you can see in the picture, one of the Venturi is burnt. I’d like to know if there is any interest in the carb, maybe for parts. The shafts are loose.
Edit:
Asking $80 per post #4
(Edit by Moderator)
If you're looking for that exact List number, yeah, hard to find, especially in Europe. If you're looking for a replacement, it's likely a OE Holley 600 cfm with a Mopar throttle lever and a hot idle compensator. There's a bunch of them out there, I see them at swap meets for $10 - $40.
The steel plugs in the fuel bowls tend to weep as they age. Epoxy is a common fix.
What were you looking to get out of it? Can the venturi be replaced?
I'm sorry I didn't check the messages anymore, since there was no response.
Would you still be interested in it?
I'm asking $80.
I honestly have no idea if the venturi can be replaced.
Greetings Jimmy
I'm asking $80.
Greetings Jimmy
Boosters can be replaced with proper tooling
