Blue dot advance springs
snake
5:23 PM
canada
Will the 2060 blue dot springs says for the 440 will lt work on my sb original dizzy.thanks
Anyone know 52 views and no answer
Only difference between A, B and RB dizzy's is the length of the shaft/housing. All the internals are the same.
Mark
Mark
Since the A and B distributors rotate in different directions, I thought there would be other changes inside as well.
A engine distributors use different centrifugal weights and the housing is different.
And the shaft, and the advance can.
So all that's the same really is the 2 plates + pickup, reluctor wheel, and rotor shaft
Pretty much what I said, the guts are the same. The OP was asking about advance springs, and there are no big block or small block springs, they just vary by advance rate. Try to read the entire post to understand the answer given.
Mark
Mark
I didn't disagree your post, nor was I incorrect.
Hope your day gets better
Cheers
