Aluminum cleaner aluminum Dana 60
Well the last one I did was also used, but it had a coat of chipped paint on it that I wanted to match.
I washed it, soap and hot water, blowed dry, wiped with acetone, air dried, spray can primer, (better primer would be a much better choice on naked aluminum) and some race hemi orange from Mazzolini .
Happy so far, did the heads the same way.
Aluminum requires an etching primer for best results. Local parts store should carry it.
Hope you used this? It doesn't say high temp.
I have and it held up fine. Does your intake have a exhaust cross over? That would be a real hot spot for any paint. Many don't go to the extent to use an etching primer and the paint holds up fine as long as it's really clean. I use it because it's aluminum.
The etching primer is only applied with a couple of thin coats.
