Stock valve cover clearance
71_Duster
1:10 AM
Alberta
Does anyone run stock valve covers on a 440 with Edelbrock heads and Hughes rockers?
I have some no name stamped valve covers that are slightly taller but they won't stop leaking. I think the shape is slightly off on them as all the gaskets I've tried never fit the corners very well.
The spacers are a good idea for roller rocker arms (at least the Harland Sharps I prefer), though with some rockers you can hammer on the OEM covers' oil baffles for clearance.
Before Medici made them, I was making them - a few years ago & don't have any left - and I was losing my butt selling them to Mopar guys at about half that price. Medici's are nicely finished.
Was hopeing for a cheaper alternative/answer as those are $230 bucks Canadian plus shipping, brokerage etc.
Does anyone have a stock valve cover they can measure the inside height from the mounting surface to the baffles?
You can make the factory VC clear those rockers
71 Duster - Any luck
If I need to start a new thread , no problem
Not having a lot of luck with the search function on this subject
Anyways , with my situation not really a clearance issue
Factory stamped steel rocker arms on 5090 heads
Bottom line
Will the Factory Stock 1971 Valve Covers fit and seal well with the Edelbrock Aluminum Heads
Been running the Edelbrock Signature Series Valve Covers with zero issues for the better part of five summers - Not a drip , just gaskets no sealer
Other then the color and the Edelbrock stamped within the valve covers
I would love to go back to my factory valve covers , but not going to waste my time with leaks and improper fit if they won’t seal well
5090 instructions say the heads can bee used with factory valve covers
Looking for options
Thanx Scott
And if I need to start a different thread no problem
I’m running stock ‘68 383 valve covers on Stealth heads with Harland Sharp rollers. I marked baffles with dykem, then drilled 5/8 holes where adjusters hit baffles. Works great!
