Purepony
I know it’s not a n body but I’m assuming it’s similar. This is for a 74 e body.
I’ve been trying to adjust the camber per what I’ve read online, which is front bolt, facing the front of the car, all the way out, rear cam bolt, facing the back of the car all the way in.
Basically front part of the arm out rear part of the arm in.
This is on a stock suspension car. The only upgrade is hemi torsion bars that were put in about 10 years ago.
For whatever reason one side seems to have more positive camber so I believe the passenger side to be correct. However, the driver side has negative camber ( too much) even though both arms are set to front out and rear in.
Basically, my questions. would any of this be related to the strut rod or any other part of the suspension like the torsion bars?
Could there be another part that’s binding for example and holding or throwing one side off?
should I just set them so they both match in view by eye ? Because I think I could do that I think I can make the passenger side just like the right, even though it’s going to require different settings on the Cam bolts so I know for a fact the settings on the Cam bolts won’t match.
Another thing I’m wondering is, should I release all the suspension like the strut rod, the torsion bar, the lower control arm and reassemble it? To see if anything was binding
And if I do that, do I torque everything to specs with the suspension weight in the car ?
I know it’s too much, but I’m losing my mind over here. I’ve been at this for a couple of days and for some reason things are not lining up
See pics
. You can see the gaps in the fenders
Thanks everyone
See pics
Thanks everyone
