After taking ownership of the car I hunkered down to get to the bottom of a few issues that dad never quite got to.
1) The gas gauge didn't work.
2) The engine got hot when in stopped traffic.
3) The drivers brake light would intermittently fail to work.
4) The generator wasn't doing the job at idle.
I was proud as a peacock when I told dad I had fixed all that.
- I cleaned the potentiometer on the sending unit and that fixed the gas gauge issue.
- I installed a triple core radiator and a 6-bladed flex fan. That cured the overheating issue.
- After countless attempts to repair what I thought might be bad wiring or ground on the tail light assembly, the issue was that the turn signal switch wouldn't return fully home after a left turn. Manually "homed" the turn signal stick every time and that was the fix for the brake light issue.
- Brought the car to Golden Alternator/Starter on Elmgrove Rd in Greece, NY and they updated the existing generator/VR setup to an alternator (one wire IIRC). I believe those folks are still in business today. That cured the charging issue.
After all that, we stripped all the paint off. And tons of it. Body was solid all around. Just as dad suspected when he ran his magnet all over it before buying it. We repainted it black. Here's what it looked like. We redid the exhaust to exit out in front of the rear wheels. Thrush mufflers. Air shocks on the rear. Had one snag where I couldn't locate a rear drum for it. Wound up finding a match from a '58 Edsel down in a FL junkyard through an old Hemmings catalog.
Of course, today, I'd slap myself silly for doing that, but back then, very few people cared, including, obviously, me.
