- 12:47 AM
- Apr 13, 2012
- Granite Bay CA
I had the engine out last year at this time....
I went through it.....new dished pistons to lower compression a bit, refresh the heads, some suspension and steering mods since it all was apart.
I pondered a switch to a roller cam at the time but kiboshed it. Cost was one factor. Another was that I had a good used Lunati solid flat tappet cam that I'd used before.
I don't necessarily regret using it but it clearly isn't an ideal cam for the combination.
Here is the cam card....
I have 1.6 ratio rocker arms so the lift is even higher than shown on the card.
This isn't a drag car. I am not a straight line racer either....My interests focus on strong street performance with an intention to make some laps on a road course.
The compression ratio is around 9.8 to 1 with Edelbrock aluminum heads. It idles okay and makes good power but I suspect that I could do better.
The idle vacuum from this combination is inadequate for the power brakes so I slipped in a vacuum pump. It works but it feels like a crutch.
I had a Mopar Performance 528 solid in the engine before. It wasn't quite as strong but it did run decent. It had great vacuum and worked great with power brakes.
Lately, I've kicked around the idea of actually making the leap to a roller cam IF one could be spec'd to improve power, vacuum and overall drivability. With the little that I know about roller cams, I have a feeling that it is all possible.
It seems to me that this Lunati is probably too much for this engine. I think this because the '528 was by comparison a LOT smaller yet not that much slower than it is now.
I just wonder if the Lunati specs are better suited for a larger engine with better heads and more compression.
The engine isn't soggy or sluggish but the low idle vacuum annoys me. It certainly isn't as snappy under 3000 rpms like it was with the '528.
My curiosity about how a properly chosen roller cam may deliver more vacuum, more power and maybe even better mileage creeps into my head sometimes.
This engine is a .040 440 block, a 4.15" crank and measures out at 495 cubes. 9.8 to 1 compression with 2" headers, 3" exhaust, 5 speed manual with 3.55 axle gears. The car is just shy of 4000 lbs plus me.
Does anyone have a car set up like this one with a roller cam you like? Care to share the details on your setup?
