Fire extinguisher
Aron Gleason
1:59 AM
Washington
Looking at either a clean agent fire extinguisher or a dry chemical fire extinguisher? I really don't want to spend a lot of money, but want to make the right choice on a fire extinguisher. Anyone have some good feedback?
The main consideration would be what
type of fire you might see in a given
situation, and which you might expect
to encounter. A garage fire is different
than a car fire. I've experienced both.
There hasn't been a time when a
2-1/2lb type ABC was absent from
my Jeep. And my garage has a 5lb
ABC. Both worked to put the fires out.
They do leave a powdery mess behind,
but worth the effort of cleaning up
if it saves your investment.
For my recent build I bought a foam
type extinguisher that's the size of
an aerosol can. Fits good in the
glovebox with nowhere to mount a
2-1/2lb.
I spent 20 years as a volunteer firefighter with a rural department. Speaking from experience, if you experience a car fire, and do not have an on-board fire extinquisher, by the time a fire department is notified and arrives, your car will be toast. Pun intended.
You want Halotron. if you need to use powder you’ll be wishing you had bought the Halotron. Powder not only makes a huge mess but it corrodes almost instantly. You’ll never dig it out of the electrical connectors, nooks and crannies. If your engine bay catches and you nail it with powder you’ll be restoring the engine bay and buying a new wiring harness, hopefully not the bulk head.
That makes sense, thank you for the heads up.
Halotron is not rated for class A fires
in the 2-1/2lb and 5lb extinguishers.
You need an 11lb before Halotron is
rated for class A fires.
(Class A=wood, paper, plastic, fabric,
as a fuel source).
An 11 puunder takes up a lot of space.
So what are you worried more about. Your fire extinguisher $$ or your car/house ? $$
Do you want the cheapest heart surgeon or the best ?
Has nothing to do with $$...
Most don't want a big honkin
bottle mounted somewhere in the
cabin. No sense in mounting a
fire extinguisher in your car if is
not rated for A,B,C type fires.
B and C are the main concerns with cars. Small Halotron extinguishers will have an effect on A fires, just need more juice for UL to approve it for A.
It would be for the car so I definitely want a good fire extinguisher without the mess.
Another suggestion would be to tape a 1/2" wrench to the extinquisher to loosen and remove negative battery cable.
  • Offering 50 seconds of fire fighting protection
  • E50's extremely small and lightweight construction allow for storage almost anywhere.
  • Internationally tested and certified. Unit does not automatically deploy when exposed to fire. Manual deployment.
  • More than 4X the fire fighting time of a 5lb fire extinguisher
  • MAKES NO MESS Leaves no residue. Non-toxic, non-corrosive & environmentally friendly
  • ZERO PRESSURE DISCHARGE Creates no thrust that can otherwise spread oil & liquid fires
  • SAFE & MAINTENANCE FREE Solid construction has no moving parts or compressed gas to ever service
Prolonged Exposure to Halon Can Be Toxic
The toxicity of the Halon gases makes them dangerous to use in confined spaces. If it is to be used in such scenarios, precaution is required to minimize any inhalation of Halon. Avoiding all unnecessary exposure to Halon is considered good practice. This is because exposures to concentrations of 7% for more than 15 minutes can be very dangerous. The risk is minor when exposed to Halon in the 5-7% range as no noticeable effect can occur. However, at levels between 7% to 10%, the likelihood of toxicity increases significantly. That’s why, in places where Halon is still used and needed to be used, it is highly recommended that operators evacuate the space before proceeding.
If Health Risks
There are a number of health risks associated with the use of Halon extinguishing agents. These include the following:
• Frostbite: Skin that comes in contact with the liquid of Halon can cause frostbite and chilled skin issues.
• Suffocation: High concentrations of Halon can cause people to suffocate. This is because it can create an oxygen-deficient environment.
• Eye and Skin Irritation: Since Halon is toxic, it can cause damage to skin and eye. Irritation can occur even if there is no direct contact with Halon.
• Cardiac Sensitization: Halon can cause an increased heart rate and irregular heartbeats in response to adrenaline. It can even cause a heart attack in extreme cases.
• Interruption of the Central Nervous System: Inhalation of high concentrations of Halon can interfere with the proper functionality of central nervous system. In such cases, symptoms of tingling sensation and dizziness is expected. A victim can even go unconscious in some cases.
If Health Risks
Halon is dangerous if you have no ventilation. Under the hood outside should be safe.
