MIKESPOLARA
I've been in the middle of trying to change my 22" radiator in my 63 Max clone. Wasn't overheating but the temp does go up a little at freeway speeds which indicates lack of radiator cooling as opposed to air flow issue which is usually seen at idle-low speed. I was looking at the US radiators but saw auto city has a aluminum with 2 1.125" tubes, which is good. In the picture it looked mostly correct. $259 versus US $850. Well the Auto City unit listed for 62-64 cars does not fit. Let me repeat DOES NOT FIT. Core size is good, tanks looked very similar. The brackets are set 1" too far back, towards the engine. So I made spacers to fill the gap. Hung the radiator needed to shorten my fan spacer, no big deal. But I had noticed the filler neck looks like it stands taller then original. It does, about an inch taller. can't close the hood because it hits the rad cap. So I thought I could lower it to clear, yes but doing that puts the lower hose right in front of the oil filter and there is no way to install lower hose without crushing it, not good. After a month of playing with this I gave up. Ordered a US radiator from Classic Industries. US direct has a 4-6 lead time where as Classic Ind had it in stock. Hopefully this one with be a drop in as stock. I went with the copper/brass 3 row.
Do not buy the ACC 63-65 22" alum radiator
By the way, the OEM radiator I took out must be original for my car, it's for a small block car and is 2 rows of what looks like 3/8" tube. Surprised it works as well as it does. The replacement I bought has 3 rows of 1/2" tube should be better
