gkent
Honing them is as simple as buying a brake hone and sticking it in your drill. And GO EASY - its amazing how much material is removed with only a couple strokes !!
Thanks, what tightness should I aim for?Honing them is as simple as buying a brake hone and sticking it in your drill. And GO EASY - its amazing how much material is removed with only a couple strokes !!
I don't think you want any more than a thou. As long as they move freely but not loose.Thanks, what tightness should I aim for?
so the nice Hughes 1620 shaft does not fit sadly....
Mine are factory max wedge rockers.Wow, apologies if we've gotten off track here....
Do you know the original application for those rockers?? Are they factory or aftermarket. Not a whole lot of factory adjustables out there...... I do have some here tho, I'm going to have to look and see if I have shafts and what they measure... It would be good to know what the real clearance should be.... trying to think just where I could find that info.... maybe measure a different set??
Ah wait, you made me go out into the garage and measure again and now I noticed that the shafts had been tourqed too hard, they are egg-shaped!How are you measuring? Seems odd that they would be under .875.
Those look awful straight for max wedge... I have some of those too, and some others. I'll have a look at some of this stuff and report back.... Really hope were arent looking at some old 273 rockers there!!, but I'm not the greatest at just comparing by pix on sight....Mine are factory max wedge rockers.
LoL, surpirised someone did'nt tell you to look out for that earlier....it happens, a lot.they are egg-shaped
Thanks, that would be great.Those look awful straight for max wedge... I have some of those too, and some others. I'll have a look at some of this stuff and report back.... Really hope were arent looking at some old 273 rockers there!!, but I'm not the greatest at just comparing by pix on sight....
What about honing them or bush them before install.Use factory shafts. Poly engines had the same type of rocker....& shafts & ran just fine.
Nope. If they aren't scored from use then leave them as they are.What about honing them or bush them before install.
Overkill or will it make them last longer?
??? Who says they're .872 ??? .003 in addition to whatever the rocker clearance is will spew oil like crazy/ You actually want a close (not tight) tolerance so there is pressure in the rocker otherwise the bottom surface won't get any oil. Spring pressures, etc will just squeeze that area dry.all these new .872" aftermarket shafts
??? Who says they're .872 ??? What you want is a thick wall, round .875 shaft.
Over the years I've torn down a bunch of factory big block engines and several had hardened shafts. Was it whatever the vendors sent them or did just the HP engines have them? I'm pretty certain that some of these came out of regular passenger car engines. Some shafts were fairly soft against the 'file test' and some were hard enough to mark the file. I've used the Isky ductile iron non roller rockers on factory 'hard' shafts and they did fine turning 7300 in the lights.After screwing around with crane and isky irons and fighting the galling issues and geometry, I found that Harland Sharps were actually the best value. Use the “E” versions for Eddy/Trick Flow/Stealth heads. Regular version for factory iron heads. No expensive “correction kits” or special shafts required.
How many shafts have you had that didn't fit a stock head, factory or aftermarket? I can see an aftermarket shaft not fitting....and what size were the TRW shafts and how do you measure the saddles on a stock head....since they are not quite a full half round?One thing that's worth considering ... what size are stock Mopar shafts? The rocker stands on the heads are machined to accept that size. If, for example, they're machined for .872 shafts then the .875's are not going to fit. That's something you don't want to start messing around with. Trying to bolt them down is going to bugger up either the shafts or the heads!
That said, I've owned a number of sets of Isky rockers like yours and NEVER had a set that didn't fit on a set of stock-size shafts. I used to use TRW shafts back in the day which were thicker than stock shafts and had a ground surface finish
