Charlied
Have my Thermoquad apart and with a suspected internal fuel leak. What can I use besides gas to fill the wells to test for leaks.
Can't use water surface tension. Fill a glass of water then very carefully, you fill can it above the rim. Glass has to be dry around rim.If its all apart you could use water.
............What can I use besides gas to fill the wells to test for leaks.
As Fran pointed out. Water won't show leaks due to surface tension.If its all apart you could use water.
ThanksIf you're worried about the smell in the house, you can also use low odor paint thinner.
Will use gas and do it outside.As Fran pointed out. Water won't show leaks due to surface tension.
Just use gas.....![]()
AVS2Almost ready to quit the thermoquad, and recommendations on a Edlebrock replacement?
