Superbee Sean
1968 Super Bee that will stick with a Carb, not F I. 3/8 sending unit with return, or 5/16 with no return……that is the question……
Yep. Can't say I've been experiencing any issues with cranking up (cold or hot), either.3/8" line and no return is what I run on my strokers.....
I have the vapor separator on my car and have a lot of raw gas smell, are you saying that system could be the culprit? It wasn’t always like this, but it’s pretty bad now.Start and drive vs, start, warm-up, smell fumes....etc.
You more than likely have a leak. Sometimes they are hard to find. I had a heavy presence of raw fuel and found a small leak at the fuel pump. Finally found it but it took some patience. It wouldn't leak at idle but would at fast idle.I have the vapor separator on my car and have a lot of raw gas smell, are you saying that system could be the culprit? It wasn’t always like this, but it’s pretty bad now.
