Pretty interesting!
A simple click on the link would have answered that one....Who or what is UTG???
BOB RENTON
Not just the offset, I have a ‘70 ‘Cuda N96 Shaker… very evident when the hood is up. I never knew about the centerline hole for the drivetrain. You can see it here on a ‘68 Sport Satellite rad support. So it’s the same on all ‘68-‘70 B bodies.Heck, I always thought the offset was common knowledge in Mopar world.
Maybe not...
The offset is, the hole is not.....at least I will admit I didn't know that tidbit.Heck, I always thought the offset was common knowledge in Mopar world.
Maybe not...
Tony also made a good point about being left hand drive, the added room for the steering column, brake master cylinder, and clutch linkage that my Charger and ‘Cuda have.The reason for the offset in the drive line is to control or counter act the TORQUE reaction of the engine (torque opposes rotation) and the same thing is true for the rear end (axle tubes are different lengths + axles) and the reason for differrnt number of spring leaves.....5 + 2 half leaves, right side and 6 leaves on the left side. The concept is fundamental...especially during intense competition....aka drag racing and 4 speed cars with hammer starts.......
BOB RENTON
Not just those. As Tony said, it's across several body types and several years of Mopars...Not just the offset, I have a ‘70 ‘Cuda N96 Shaker… very evident when the hood is up. I never knew about the centerline hole for the drivetrain. You can see it here on a ‘68 Sport Satellite rad support. So it’s the same on all ‘68-‘70 B bodies.
The old wives' tale I heard back in the day was that it was to help offset the drivers' weight in the car....Tony also made a good point about being left hand drive, the added room for the steering column, brake master cylinder, and clutch linkage that my Charger and ‘Cuda have.
I meant the one I pictured is the same ‘68-‘70 b body. My ‘70 ‘Cuda is the ‘71 B body under hood, and is probably the same as that, and different than the earlier years.Not just those. As Tony said, it's across several body types and several years of Mopars...
I first noticed it in the early 80's, though, on an original SixPak fiberglass hood for a 'Bee I had.
Scoop up top is dead center; the hole for the air cleaner underneath is not.
He was a writer for a lot of 80’s-90’s car magazines on the east coast. High Performance Mopar, Cars Illustrated… and others.Who or what is UTG???
BOB RENTON
You should start a channel:Who or what is UTG???
BOB RENTON
It’s probably just a variation hole when everything is jigged up on initial fabrication. Once the line is up and running, it’s not used. Like Tony said, there are holes pinned for alignment.Ok help me understand. I have no doubt that hole is a centerline, and I am clear on offset, but who during the course of assembly used the hole as a reference when building the car since the motor came up from the bottom already bolted to the K frame, and trans cross member also has pre determined mounting holes, where did the designers see its need/use? I doubt they were designing it for future car guys doing engine swaps.
There must be some adjustments during assembly that this was used and I know one of you has the correct answer.
Inquiring minds want to know.
It's my understanding that for You Tube to pay you you have to have at least 20 minutes of content.I could have charged an electric car in the time it took him to get to the point
